Released in March 2017, the G6 is LG's flagship phone running Android 7.0. This device is available across all major wireless carriers. Physical repair of this device may eliminate water resistance and cause the device to be vulnerable to water damage.
Cannot open LG G6 back to replace battery
I am having trouble opening the back of my LG G6 phone to replace the battery. I bought the iFixit repair tools with the decice you heat in the microwave and place on top of the phone to loosen it up. I habe tried several times and still haben’t been able to get it to lift up. Any suggestions?
Thanks
Adam
Add a comment
1 Answer
Something I do that you might try is use sturdy playing cards to try getting under the corners of the back glass (using a sliding motion along the edge of the glass) once you’ve heated the back glass of the phone (either with the iOpener or with a hairdryer/heatgun). Once you get a tiny bit under the glass, you can insert more cards under the glass and the already inserted card, then slowly go around the phone and cut the adhesive holding the back on. The phone should be hot enough that you can just barely touch/hold it, in my experience - make sure the glass is very heated, as the adhesive on there is quite strong and can cause the glass to break if you put too much lifting pressure on the glass before getting through all the adhesive. If you do it right, you can even keep the original adhesive intact.
Add a comment
Add your answer
Adam Pease will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 231
