The Alienware 17 R4 (17.3 inches) is a gaming laptop, released by Dell in 2016. (AW17R4-7000SLV-PUS)
20 Questions View all
My fan is making a loud grinding noise
My fan is making a grinding noise. I believe the bearing is bad in it as it doesn't want to spin like the other one. When I have the Bottom cover off and I turn it on, it's struggling to spin. How can I go about removing that fan and replacing it?
Score 2
Add a comment
1 Answer
Chosen Solution
Hi @kstorm
Well, I would suggest you to follow the below link to remove the parts
Alienware 17 R4 Battery Replacement
Follow to step 23.
The fan should be holding by with some screws.
remove it and use it as a reference to compare and order replacement.
You can purchase replacement fan at ebay, aliexpress, etc
Example:
https://www.ebay.com/sch/i.html?_from=R4...
Score 3
2 Comments:
Hi @kstorm ,
Just to add to the answer, here's a video that shows how to remove the fans.
by
@jayeff thumbs up :)
by
Add a comment
Add your answer
Kyran Storm will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 18
All Time: 7,778
