Updated version of the 2016 Retina MacBook. Model A1534, EMC 3099. Now features faster Kaby Lake processors up to 1.4 GHz Core i7 with Turbo Boost up to 3.6 GHz and up to 50 percent faster SSD, and supports up to twice the memory.
82 Questions View all
MacBook has not been charging and is shut down
My MacBook has not been charging with a USB-C cable. I have tried multiple cords but none have worked, it is a problem with the computer itself. I looked into the charging port and there is no debris. It is out of battery so I cannot turn it on, I am not sure how to fix this.
Thank you!
Score 1
Add a comment
1 Answer
Does your MacBook charge when you connected your AC adapter to another USB-C port? They all can operate in both modes as a data transfer interface and as a charging port.
Also there’s catch with MacBook chargers… Inside of those cables (in USB-C connector, to be exact) is a controller that basically decides how much power will adapter provide… And the stupid thing is that those controllers are all locked only on one specific number of watts (45, 65 or 85), so they are not interchangeable that easily… Louis Rossmann covered that topic with more detail. But if you know someone who has an USB-C capable monitor that can also charge laptop, try that. Or ask someone for their charger for testing purposes (don’t forget to return, though :P). If nothing works and MacBook won’t boot while plugged in to AC, then you have faulty power controller, looks like. After that you did everything you could, and now go to a repair shop with decent reputation (not Apple Stores or AASPs, that won’t end good).
1 Comment:
desafortunadamente no fue util lo que me queda saber es si elprovlema es la bateria. lametable los talleres de "REPARACION " para productos Apple no son confiables y en muchos casos el remedio ofrecido es peor que la enfermedad, estuv confiado que la bateria seria el problema, otras pruebas que hize no funcionaron solo me que la duda de la bateria.
Confie de que el problema era el ADAPTADOR y como no podia verificar decidi en mi viaje a California comprar uno nuevo y no fue asi solo que me queda abrir la computadora y sacar la bateria y y testear para saber si finalmente es el problema. etc.
by
Add a comment
Add your answer
Christine Hagan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 6
All Time: 239
