Released online on January 16, 2009, the Inspiron 1545 is a 15.6" budget PC laptop available with 3 or 4 GB of RAM. It succeeded the Inspiron 1525.
66 Questions View all
Why wont my battery charge?
i have a Dell Inspiron 1545 that wont charge, i have bought a new battery and charger (i left this thing in storage for over a year) and after i turned it on after a long time i get a message saying “ plugged in,not charging , i have tested the battery and charger on a relatives laptop and it works fine, what could be my problem?
Add a comment
1 Answer
Most Helpful Answer
Seems like the issue. could be with power relay/controller. Since it doesn’t deliver any current to battery, then it is most likely a faulty battery connector or somewhere in-between relay and connector an open end. (Assuming from the fact that AC still delivers power and your laptop runs just fine on AC alone.)
Score 1
2 Comments:
i have been trying to search for a solution google and seen a big amount of people have the same problem( some cases go as back as 2006), so a problem with the plug of motherboard would be likely, i will see if i can pry the laptop open to examine for any visible damage.
by
Plug of battery, I hope, you mean?
by
Add a comment
Add your answer
Carlos Cervantes will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 236
