1.4GHz or 1.6GHz Processor / 64GB or 128GB SSD
162 Questions View all
MacBook will not charge.
I have tried a new charger, but it’s the same. Sometimes I get a solid Orange light, sometimes green. It stays on 0 percent, and doesn’t move.
When I look at the battery statistics it says that the capacity is 5246 and 627 cycles.
Any ideas?
Update (12/19/2018)
The light is now green but still no charge. Its solid green.
UPDATE (07/19)
Sorry to resurect this but I’ve only just got around to a new I/O Board attempt.
Was strange as before it was always on 0 - 1 percent and not charging, replaced the I/O board and now its on 20 odd percent, still not charging, and battery is being used but going down.
Any other ideas as I’ve tried a new I/O Board and 2 new batteries now.
Thanks!
Score 1
11 Comments
Lets take a deep look here run this gem of an app CoconutBattery take a snapshot of the main window with the MagSafe charger connected and a second snapshot with it removed. Paste them here for us to see Adding images to an existing question
by
try a different dc in board
by
What’s that involve, is it doable myself?
by
the i/o board guide that trevor posted
by
Did you have a liquid spill at some point? I'm thinking the charging logic within the logic board is damaged.
by
Show 6 more comments
Add a comment
1 Answer
Most Helpful Answer
Two possibilities:
Most likely possibility: bad battery
MacBook Air 11" Late 2010 Battery Replacement
MacBook Air 11" (Late 2010) Battery
Less likely possibility: I/O board
MacBook Air 11" Late 2010 I/O Board Replacement
MacBook Air 11" (Late 2010) I/O Board
MacBook Air 11" (Late 2010) I/O Board Image
Product
$74.99
MacBook Air 11" (Late 2010) Battery Image
Product
$79.99
MacBook Air 11" Late 2010 Battery Image
Guide
Difficulty:
Moderate
15 minutes
MacBook Air 11" Late 2010 I/O Board Image
Guide
Difficulty:
Moderate
Score 1
Add a comment
Add your answer
andy hawkins will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 234
