Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Dirty Ports?
There is a lot of buildup of dirt on the case where it recesses into the port openings. Is it a problem and what is the best way of cleaning it?
Score 2
1 Comment
I used a blending/ fluffy make up brush and that did the trick. Soft, clean and easy to get. I found it easier to use then the q-tips
by
Add a comment
Chosen Solution
use q-tips or compressed air to try and clean the ports
as for it being a problem there shouldn't be one as long as it doesn't mess with the connection
Score 3
1 Comment:
Its too stuck for compressed air but i will try the q tips
by
Add a comment
If the muck is really stuck on, you can use a small amount of alchohol on the Q-tips to help unstick it.
Score 2
Add a comment
Q-Tips or dry cotton wool should clean your ports well.
As for the mag-safe charger port, the magnetism can hold some dirt to it. This can be hard to remove but Q-tips and a little extra effort should clear it out
Score 2
Add a comment
A soft toothbrush can be used to loosen debris, then use a little compressed air to blow it out. If you are going to use alcohol, be sure to remove the battery first, to avoid shorting anything out.
Score 2
Add a comment
I advise against alcohol, if it get's in the port- your port may end up permanently screwed. Ditto at the compressed air though.
Score 1
Add a comment
Used a clean make up brush and that did the trick of removing any sand, dirt, lint from the charging port
Score 1
Add a comment
Add your answer
AussieMac will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 20
All Time: 11,468
