A collection of guides and support to help with washer repair.
Samsung Washing Machine Not Draining
I have a Samsung front loading washing machine (model number WF206BNW/XAA). I received an error code of ND which means it will not drain. I removed the drain pump and checked for clogs. I did find a penny inside the drain pump influent line which I removed. The pump impeller and motor looked fine. The drain hose looks fine with no clogs or kinks. I reassembled everything and tried another cycle. Everything is fine until it gets to the rinse cycle and I get the ND error once again. I thought maybe the pump was bad so I hooked up a connection to an old power cord I had and plugged it in to a 120 V outlet to see if it would spin. It did spin so I know the drain pump motor is fine. The impeller is fine. I reinstalled the drain pump except instead of hooking up the electrical connection to the connection from the washing machine I left my homemade connection hooked to the drain pump. I ran a cycle and when I get the ND error I just manually plug the drain pump electrical connection into the outlet and drain the water out. It works fine. There must be something else preventing the signal from getting to the pump. Any clues?
Add a comment
1 Answer
Chosen Solution
I hate to tell you this but it sounds like you will need a new control board. Since you can manually operate the drain pump, and it drains, that's not the problem. The control boards on the Asian brands are filled full of silicone goop, so component level repair is impossible. You could check the wiring between the control board and the pump, there could be a loose connection or broken wire. LG and Samsung are notorious for discontinued parts, so it may take some hunting to find a used one for your washer.
Score 1
3 Comments:
Same issues here with with washing machine plus every time I purchase samsung product it,'s junk
No more buyers be aware
Samsung= JUNK
by
I purchased a new control board but still have the same issue. Is there a relay switch to check?
by
I'm investigating the same problem. Mine is a WD8704. In my case the suspect relay is on the control board. I am hoping a replacement board I have managed to source will do the trick, however as you have replaced the board, your problem probably lies elsewhere. I hope you find the solution, please post back if you do. Just for information it is possibe to replace a relay on a PU-embedded board as is demonstrated here, it's a bit of a hack but worth a go if a replacement board is not available https://www.instructables.com/Samsung-Wa...
by
Add a comment
Add your answer
David will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 30
Past 30 Days: 156
All Time: 4,905
