Repair guides and support for electric and stove-top kettles.
The handle falls over
I have a 40 year old Asta stove top tea kettle and the handle falls over, so the wooden part of the handle ends up in the fire. The screws that attach the handle have been tightened, but what looked like rubber washers have broken down with age. What would be able to withstand the heat from a gas burner to replace the “washers” ?
3 Comments
Silicone is significantly more resistant to heat than rubber.
by
Thanks! Will try to track some down
by
Thanks to you both!
by
Add a comment
1 Answer
Most Helpful Answer
Here is a chart to help you determine the inside diameter of washers:
https://www.engineering.com/Library/Arti...
The get a fibre or nylon washer set.
https://wbpartsexpress.com/5610-277-62?p...
Score 4
Add a comment
Add your answer
MM Harvey will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 10
All Time: 449
