An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
140 Questions View all
Why my Barista start dripping the espresso very slowly out
It stopped pouring the espresso like used to be now is just dripping very slowly. It took me 10 minutes to make a single shot of espresso this morning. I love that coffee machine i been having it from 10 years.
Score 1
Add a comment
Chosen Solution
You're most likely looking at one or a combination of these issues:
- Coffee ground too fine
- Coffee tamped too hard in the basket
- Brew screen clogged
- Portafilter clogged
Does water flow through easily with the portafilter removed from the machine? Then your screen is probably fine. Does water flow through the portafilter easily when there's no coffee in it? Then your portafilter is probably ok. You're then looking at a grind/tamp issue, not a problem with your machine.
Score 3
Add a comment
This unit is likely the same as the Rio Vapore - HERE is the manual
Page 28 - troubleshooting may assist
These iFixit Starbucks Barista Guides may be useful too!
HIH
Score 1
Add a comment
It has happened to me and I went to several forums to try to fix it and it just wouldn't work. In despair I just used CLR, or a generic Calcium Lime and Rust cleaning spray directly on metal filter container and VOILA worked like a charm. I just sprayed the metal cup and inside the portafilter, let it sit for some 10 mins then rinse very very well. Unbeknownst to be, I have hard water and the little holes where coffee was supposed to go thru were clogged.
Score 1
Add a comment
Add your answer
pavel zlatev will be eternally grateful.
Past 24 Hours: 13
Past 7 Days: 87
Past 30 Days: 376
All Time: 41,002
