The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
60 Questions View all
Laptop shows no sign of life but board heats up.
I have an ASUS X555L and it seems to show no signs of life the board heats up but that’s about it the f an doesn’t spin and the screen back light doesn’t turn on i’ve tried changing out the RAM but that didn’t seem to work! Anyone have ideas its got an i7 so i’d really like to use it as a on the go machine.
Add a comment
1 Answer
Chosen Solution
Hardware failure is almost certain.
It’s important to run some tests to ensure whether the motherboard is dead or not.
Computer Motherboard Troubleshooting
If the issue is really in motherboard. Chances are, you can retrieve data from the undamaged hard drive of your dead laptop.
https://www.minitool.com/data-recovery/d...
Hope this info helpful.
Score 1
2 Comments:
Thank you Albert, i have since given up on fixing the computer. It was just a side project. I’m holding onto it just in case I can de-bll the CPU since its a i7. I think i have another laptop I can put it into.
by
Welcome, I hope it helps you anyway. Thank you!
by
Add a comment
Add your answer
Corey Meyer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 185
