iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
906 Questions View all
How to repair my wet iPod
My iPod was in a child’s mouth, after that I put it in rice and left it for a week to drain as much liquid from the iPod, I then plugged my iPod to my Mac and iTunes popped up and said to leave iPod plugged in to repair, but hours passed and nothing is yet to happen. pls help.
Add a comment
1 Answer
Chosen Solution
Hi,
As you know water and electronics and electricity are not a good mix.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the player’s operating design and could damage the components.
First do not turn on your player and then you need to remove the battery as soon as possible from the player to minimize any further damage.
Rice is good to eat but does not fix the problems caused by corrosion.
Don't Put Your Device in Rice. Here's Why...
Then you need to dis-assemble the rest of the player and clean all the affected parts using Isopropyl Alcohol 90%+ (available from electronics parts stores) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain scents and is not as effective. If you do use it, check the label to verify the amount of IPA.
Here is a link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the player might possibly work correctly again.
Here is a link to the ifixit guide(s) for repairing your player.
iPod 6th Generation
If this process seems too daunting, take your player to a reputable, professional electronics repair service experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Score 2
Add a comment
Add your answer
katalina lotoahea will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 3
All Time: 84
