The Samsung Galaxy A5 (2016), an Android Smartphones released by Samsung Electronics in 2016.
59 Questions View all
Screen flashes purple everytime I turn phone on and flickers white
Everytime i press the side button to turn my phone on the full screen flashes purple and doesnt respond, it does that for like 3+ minutes everytime i press it and then decides to want to work until the screen goes off and it does it again.
ontop of that, when my brightness is low it flickers white and the longer its on low the worse it gets.
if its slightly brighter it works completely fine and i have no other issues with my phone
Add a comment
Have you got the firmware anywhere? And then the behavior is typical for this problem.
Add a comment
I did everything, reset, factory reset. I did a cache delete then reboot. Nothing worked. I turned off battery saver. I heard it was something do with power not getting properly to the display. Then I thought hey I just recently turned on biometrics for fingerprint unlock . I turned off EVERYTHING to do with finger print scanner and biometrics. Haven't had a problem since! Hope this helps. Try everything before getting new screen!
Add a comment
Add your answer
idek will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 824
