The third iteration of the 10.1 inch Galaxy Tab tablet.
125 Questions View all
Broken cable clamp on Orange flat cable
After replacing the battery on my 10.1” galaxy tab 3, the little bar clamp on the orange cable broke and the cable does not clamp down in the slot. Swiping the screen is now erratic and often not even happening. I guess this is the problem as I have changed the battery before with no ill effects. Is it repairable?
Holding the cable in place with tape does not help.
5 Comments
Can you add a photo
by
Thanks for your quick response Daniel, can't seem to paste the copied photo. if its any help the little bar was a brown colour and snapped in the middle and both parts disappeared.
If you know how to post the picture I have it.
by
You can edit the post and add a photo. Click on options and edit
by
Sorry Daniel this isn't working for me. I'll report back after the white tak attempt
by
https://www.dropbox.com/sh/axs768psmbm9m...
I have dropped the photo into here, hope it helps because the white tak solution has not performed
by
Add a comment
1 Answer
Chosen Solution
im guessing its this you mean dennis. yes they can be repaired but you need the proper tools to replace it. i have only done 1 on a tab e before
Score 2
13 Comments:
looks like that. I am not hopeful for a good outcome.
It is taking a long time to charge now and as it is over 6 years old I feel it's race may be almost run......
by
the charging issue could be a bad charge port or the charging chip is going bad
by
Are the parts easily obtainable?if so from where? it couldn't hurt to change the charging slot and maybe all the flat cables.
by
should be available on ebay
by
Cheers Daniel, I will report back any success
by
Show 8 more comments
Add a comment
Add your answer
Dennis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 750
