The BlackBerry Classic (also known as the BlackBerry Q20) was released in 2014. Model numbers: SQC100-2, SQC100-3, SQC100-5.
24 Questions View all
My blackberry classic got water damaged.
After a week and a half it is now dry, it got itto start but touch screen not working.
Can it be fixed?
If not is there an appIication that I can use to download my Contacts and pictures?
Add a comment
Chosen Solution
Hi @yolande ,
As you know water and electronics and electricity are not a good mix.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components.
First do not turn on your phone and then you need to with the phone turned off, remove the battery as soon as possible from the phone to minimize further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ (available at electronics parts stores), to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain scents and is not as effective. If you do use it check the label to verify the amount of IPA
Here is a link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to the ifixit guide for repairing the touchscreen in your phone.
Blackberry Classic digitizer Replacement
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in water damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
You could always try connecting a USB mouse via an OTG cable to navigate through the phone so that you can email your contacts / pictures back to a computer or set up the phone so that you can connect a computer to it via a USB cable so that you can access the storage folders (for the pictures - don’t know about the contact info though)
Score 3
1 Comment:
I finally managed to transfer my pics and my contacts to my laptop via Blackberry Link and that's all the data that was important for me . Thank you for answering my question but since I have this phone for a few years I think I will get a new one. Tks again.
by
Add a comment
Hi @yolande,
You should probably replace the complete LCD assembly. The same kind of damage happened to a friend of mine, I was able to replace the assembly and the phone is working again.
Pierre
Add a comment
Add your answer
Yolande Lacasse will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 534
