Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
Formatting problem with SSD
Hi. I just came out with the same problem. Brand new ADATA SU800 ssd, though, I'm trying over a Mid-2012 MacBook Pro. Computer works perfectly with the original hhdd. First thing that happened was the computer was able to
'see' it, though, it got stuck while erasing the drive, so I powered it off and put the ssd via USB. SSD works perfectly in my Windows computer. I actually was able to install Mojave over the USB. However, the utility disk doesn't see it when I plug it in the internal connector.
Any advise?
Thanks!
Update (01/28/2019)
Thanks for your reply ! Originally, it came with fat32 I believe. I just took it out of the box it came in, and put it into the macbook. As i described, initial erase didn't go through. Then I put it on my PC to check whether the driver was not bricked and using a partition utility I can do anything I want, like doing FAT32 NTFS partitions, etc. Drive works perfectly.
Whenever I put it in the mac, what I do is Commad+R to go the the disk utility, but it simply doesn't see it. Can I do some format in my PC and then put it into the mac? like ext2/3 ?
Mac is running El Capitan (with the older drive). I as mentioned, I already installed Mojave in the SSD via an USB adaptor. It works flawlessly. But it didn't work when I put it inside the mac.
Alternatively, Can I format it using the USB adaptor, in the El Capitan OS, such that, the mac will see it somehow?
I can see many options If I erase the ssd from disk utility,
thanks!
Add a comment
1 Answer
Chosen Solution
I moved this to its own question.
Your problem is still with the formatting. Please put you PC someplace out of sight!
A MS=DOS FAT drive can be accessed externally on a Mac, you can even boot from it, if it has a MAC OS X on it
The problem you are most likely running into is Apples new APFS formatting.
Put your old drive in the mac and hook up the new one externally. Use your internal Disk Utilities program to format the new drive preferably APFS. Now install you Mojave from the internal drive. When it is finished it will now reboot from the external drive. During the set up select to Migrated your data from your internal drive. When finished, put the new drive into the Mac. It should run. Now is it is running slow or you are having problems you can go back to the answer about hard drive/IR cable replacement to the 2012 cable.
Score 1
Add a comment
Add your answer
kenneth_palacio will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 645
