Repair guides for the Samsung J7 Pro. Learn how to repair your Samsung J7 Pro on your own.
J7 Pro 2017 model
My J7 2017 fell then purple ink appeared then it got replaced 2-3 times 2 unoriginal 1 original (2018) then somewhere in (2019) it fell again then i tried to turn it on but it won’t turn on , tried charging it and turning it on but still won’t respong. Does this need another screen replacement? *LCD*
Add a comment
1 Answer
Yes, it is likely that the Screen is damaged, so the ‘computer’ is on, but the screen is not showing an image.
Since it has been repaired before there is a slight possibility that the connector of the screen came loose, but I wouldn’t get my hopes up, sorry.
Mans don’t forget to test the new screen before assembly, so iff the new screen won’t work as well, you can return it.
Good luck, Brenda
Add a comment
Add your answer
UnKnOwN will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 99
