Released June 2017, the iPad Pro 10.5" replaces the 2016 iPad Pro 9.7".
145 Questions View all
iPad Pro Not Charging With Certain Chargers
Hello Everyone,
I have an iPad pro 10.5 running iOS 12 and it worked well but i bought an apple genuine lightning cable as a replacement from my old broken one and i tried it on my iPhone And It Charged Fine But When I Plugged it in to my iPad it just won’t detect that it’s charging why?
Add a comment
Chosen Solution
Hi,
There's a lot you can try on your own before contacting Apple for help.
One of the first and easiest things to try is a forced restart.
Switch outlets or ports, in case there’s an electrical or other problem occurs in your regular outlet or port.
If there's no problem with the iPad, and no problem with the power source, you need to check the cable in-between., then try a different cable.
Score 2
Add a comment
Whats the correct wattage for the AC adapter for an iPod pro 10.5 model A1709.
Add a comment
Add your answer
ryoseo1020 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 28
All Time: 1,258
