Repair information for the Harman Kardon Go Play 2 portable loudspeaker, which is compatible with iPhones and iPods.
How to replace broken speaker
How can I replace the speakers?
Score 1
Add a comment
1 Answer
If you can get into the device it should be as simple as de-soldering the two wires connecting the speakers to the main board. Then you would need to get a replacement speaker of the same size and power as the one already in the device which may or may not be a propriety size speaker.
The hard part would most likely be figuring out how to open the speaker which I cannot help with since I don’t own one and have never worked on one. This procedure is just how I have changed speakers in multiple different PC speakers or iHome type devices.
Add a comment
Add your answer
abelplus will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 24
All Time: 3,082
