The 2014 version of the Galaxy Note 10.1", running a Exynos 5 processor and 3 Gb of ram. Released October 2013.
119 Questions View all
Broken power button, battery died, how to turn it on?
Hi! So, my tablet had a sad encounter with a shower gel in a backpack and since than the power button and the volume button are not working properly. I forgot to charge it ant it went completelly out of battery. It happened beafore, but than pressing the power button really agressively worked and samsung logo appeared and it turned on.
Now agressive pressing does nothing. When I plug it in, the screen shows battery loading, so it is not dead, but I still can’t get it to turn on. Removing and pluging back the charging cord does nothing more than showing picrute of charging battery. I have some hope, that maybe when it will have more battery charged it will turn on, but if not, ale there any alternative ways to wake it up with totally broken power button?
Add a comment
1 Answer
Chosen Solution
Hi @tralaluna
As you know liquids and electronics and electricity are not a good mix.
The impurities in the liquid causes corrosion and provides circuit paths for the electricity which were not in the tablet’s operating design and could damage the components.
First do not try to turn on your tablet and then remove the battery as soon as possible from the tablet to minimize further damage.
Then you need to dis-assemble the rest of the tablet and clean all the affected parts using Isopropyl Alcohol 90%+ (available from electronics parts stores) to remove all traces of corrosion and liquids. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain scents and is not as effective. If you do check the label to verify the amount of IPA
Here is a link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the tablet might possibly work correctly again.
Here is a link to the ifixit guide(s) for repairing your tablet.
Samsung Galaxy Note 10.1 (2014)
If this process seems too daunting, take your tablet to a reputable, professional electronics or mobile phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Score 4
Add a comment
Add your answer
Tralaluna will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 1,114
