Why wont my LG Stylo 4 phone charge when I plug it in?
Ive had my phone for about 4 months and it seems good still but I just noticed last night that my phone wont charge and it cant keep the battery life very long.
Hi,
Have you tried a different compatible charger, charging cord or even connecting it to a computer via an appropriate USB cable to see if the phone charges?
If it still doesn’t charge, use a strong light and a magnifying glass to visually inspect the charge port in the phone for any lint etc., that may be lodged in the port enclosure. Also check that all the pins (5) are there and that they are all straight and parallel with each other.
If there is any lint stuck in the port enclosure (this prevents a good electrical connection between the charger cord and the phone) DO NOT use a pin or metal probe to try and remove it as you may damage the pins or cause an electrical problem in the phone.
Use a vacuum cleaner to see if this will suck out the debris. If this doesn’t work use a sharpened wooden or plastic toothpick to gently remove any lint etc.
If the port enclosure appeared to be OK obviously there is a problem with the phone. As the phone is only 4 months old, consult the manufacturer’s warranty statement that should have come with the phone (or search for it online - LG Stylo 4 warranty) as to what to do to make a claim for a manufacturer’s warranty repair or replacement
I also found out that I needed to change the power cord itself. Its good now thanks for the advise.
i have changed power cord and power adapter and plugged to computer and other stuff suggested, But still wont charge.
I just wanted to tell you that I have had my LG Stylo 4 for a little over 5 years and it just now began giving me the charging slowly message. 3 members of my immediate family have them. We all love our LG Stylo. It is definitely worth fixing. Have a eo
Hay there you can fix it easily
just follow these easy steps and after it you will fix your issue How to fix lg stylo 4 charging port problem
I am having the same problem with my Stylo 5 (c-type). I went on youtube and watched several videos on the subject and everyone of them said that dust/lint was the problem. I went on Amazon and ordered a new charging port cleaning kit. After very carefully cleaning the inside of the port, it still wouldn't charge. I also purchased a new OEM cable and wall charger. My phone still wouldn't charge. I then went to the LG warranty help pages on the LG corporate website. After filling out the required form, it was approved for service, however, the form was not accepted because of errors, I checked my information over very carefully several times, after doing this over and over 5 times, I went to the contract us page. There is no phone number, only another form to fill out. I filled out the form and about a day later I received a message back. The stated all of the horrible things that would happen if I sent in my phone and it turned out to be the result of neglect, misuse or other user caused damage, to click on this link to proceed with the submission for repair. I clicked on the link, and was back on the same form I filled out 5 times before. I went through that process again and again it was not accepted, I triple checked it and found everything to be correct, but it was still resjeted. I went back to the email they sent and replied that I was back to the same form and I could not get it submitted. After another day I received another email. It was the same one as the first one. This whole time I am without a phone, and anyone that has 2 step authentication enabled on most of their accounts can attest, you are pretty much locked out of all of them. I ended up buying a new phone. My point is this, LG makes it impossible to submit a warranty claim, and their phones are cheaply made, that's why they are so inexpensive compared to Samsung or Google Pixel. Bottom line is not only did I by the Stylo 5, but with in a few months I had to buy a nother phone, it might have been better to buy a more expensive phone to begin with, it would have saved me money and a lot of hassle.
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 67
All Time: 16,237
6 Comments
iam now on my 3rd yes THIRD LG Stylo 4 every one has the same Issue;Charging. The first 2 i had to replace just short of 90 days. They chArge slower and slower & slower than eventually stop
by Paris Johnson
mines charging wont pass 1percent
by MUBARAK ABASS
How do i get my LG stylo 4 phone to charge even though i got a new battery for it what do i do??
by Brianna Jennette
My charger will not stay in the phone. I plug it in the phone it comes back outl
by Dot Price
Hi @Dot Price
Try a different compatible charger/ charger cable to determine whether the problem is the phone or the charger.
by jayeff
Show 1 more comment
