The Dell Inspiron 3179 can be white, gray, blue or red, it’s very portable thanks to its reduced weight and size. It has some legacy components that diminish its attractiveness to tech-savvy users.
2 Questions View all
How to replace the CMOS battery? Do I need to order a special battery?
How do I replace the CMOS battery in Dell Inspiron 11 3179? Do I need to order a special battery which has the two wires and attachment or will a standard button battery fit into the fitting that I remove ?
Add a comment
1 Answer
Chosen Solution
Hi @cassarno
Looking at the coin cell battery replacement procedure in the service manual (scroll to p.39) the CMOS battery, which is insulated, unlike a standard coin cell battery, has wires attached to it which unplug from a connector on the motherboard so a standard coin cell battery won’t be able to connect to the motherboard the same way. It is not inserted into a standard coin cell battery connector.
The part number for the battery is 23.21212.091.
Here’s a link to just one supplier. It is shown only to give you an idea of the cost of the part and to show what it looks like.
There are other suppliers online that may suit you better. Just search online using the part number only in the search box of your browser to get results for suppliers of the part. (it is also the same part number for a lot of Dell Inspiron 11 3000 series laptops)
Score 2
Add a comment
Add your answer
Cass will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 206
