An SSD, or Solid State Drive, is a type of storage device that uses NAND-based flash memory to store data.
SSD failed to restore
APFS failed to invert. OSS Error 22
Update (02/14/2019)
Mac mini (Late 2014) running Mojave (10.14.3).
I was able to clone the drive with the Carbon Copy Clone app. I'll know today if it was successful after I install it.
Thanks Jonah
1 Comment
What is the exact Mac system you are using as well as the drives specs.
by
Add a comment
Chosen Solution
Success! The SSD is up and running.
Score 1
Add a comment
Most Helpful Answer
Disk Utility no longer works with APFS file systems for restoring/cloning devices. Using a Time Machine backup or Target Disk Mode on an old computer are the only ways to transfer data.
Score 1
3 Comments:
Don't know why you're talking about Disk Utility here as we still have no idea what the system is. Until we get that you're just shooting in the dark.
FYI: The cloning options are no longer present in the latest version of Disk Utility
by
Are you restoring the drive with CCC or Disk Utility? I just want to double check where you’re actually seeing this error.
by
Error was with disk utility. CCC worked perfectly. Up and running!
by
Add a comment
Add your answer
Kenneth Hillman will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 603
