The OnePlus 6T is an Android smartphone made by OnePlus. It was announced on October 29, 2018 and released on November 6, 2018.
26 Questions View all
I need to clean the speaker holes
Hi every one, i have one plus 6T, i have spoiled a hot liquid candle wax on it, and i was able to remove the damage from the screen (thanks to the screen protector) now am left with only 3 holes for the speaker to listen from (the rest is blocked with the wax), i have tried to apply some heat from the hair dryer with no luck, what do you think is the best way to solve this issue ?
1 Comment
Hi Raving,
thank you for your answer, i had tried to do this but it didn’t fix it, even i applied heat using a hair dryer then i used the needle, but the surface area is so small that the wax will be hard again while am trying to apply the push through the needle
by
Add a comment
Chosen Solution
Try putting the phone is a ziplock and use a hair dryer, the wax should flow out. Alternatively follow the teardown guide ( skip removing the motherboard) and clear out the wax form the inside. OnePlus 6T Teardown
Score 1
Add a comment
Try using a needle or a slim pin to clean the speaker holes. If you are careful, you can just take out the wax without damaging anything.
Add a comment
I usually wrap a glue-dot around a cocktail stick and use it to clean the dust out. I find that glue-dots are just the right consistancy to pick up dust, but still firm enogh not to get clogged in your phone.
Add a comment
Vacuum cleaner and a stiff toothbrush. Be careful not to push the wax further inside and damage the speaker.
Add a comment
Add your answer
Abdullah Al Rawi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 7,518
