This guide page will help you diagnose problems with the Toshiba Satellite C55-B5200.
9 Questions View all
Where is the motherboard battery?
BIOS time and date is resetting if I don't have the laptop battery in and if I don't have the laptop plugged in. In order to stop that I'll trying to change the motherboard battery. However I do not see it when I take the bottom cover off. I'll trying to find its location.
Manufacturer: Toshiba
Model: C55-B5299
Add a comment
Chosen Solution
This laptop model does not have a CMOS battery. On the motherboard you will see a spot that one should be located. If you disconnect or let your main battery run dead you will have to re-enter your date and time settings when booting your laptop for the first time.
Score 4
5 Comments:
@itsd_btech What is the solution to this problem then? My battery doesn't charge and my laptop only runs while plugged in, and needs bios time update each time I plug into a new socket.
by
I would recommend replacing the battery with an OEM quality battery. Either your battery is not recognized by the laptop or is failing and needs replaced.
by
buy a good replacement battery (about $20 USD, put in new battery and charge fully in the off position. Re-enter current date n time in BIOS and all should be well
by
Be sure to train the new battery! When they first charge they may only last 30 min to 1 hr. But after draining to about 10% or so and fully charging to 100% you will get way longer life. I train new batteries three times for best results, although the most benefit occurs after the first full cycle.
by
i replaced the main battery, it has no rtc battery, pressed the on button, the on button stays lit for 5 seconds then turns off, the dammned thing wont turn on !!!
by
Add a comment
Hi Alx,
I would guess that it may be under this cover.
Score 3
8 Comments:
@arthurshi - Authur, You must be good with Finding Waldo puzzles ;-}
by
It was one of my favorite childhood pastimes :)
by
This model does not have a CMOS battery on the motherboard. The spot you are showing in the picture looks like a potential placement. If you take the motherboard out you will see underneath there is no battery.
by
I'm having the same issue. I let my battery die by watching a movie that I fell asleep to. Now all I get is the Toshiba splash screen. No bios, nothing. There is no battery. I looked.
by
Does anyone know a fix for this?
by
Show 3 more comments
Add a comment
This model do not have any CMOS battery, …ignore the shape of battery on the mobo, there is no battery on the underside. First time I ever encountered this in my 17 years dealing with computers. It's very unusual but it's true
Score 1
2 Comments:
I have a Toshiba Satellite L55-B5267. I am also unable to locate a battery on the board. I am getting prompted for a BIOS password. How do I clear the password. No battery so I am unable to locate the correct jumper location on the board.
by
Mine did this I replaced the hard drive and reinstalled windows and boom fixed
by
Add a comment
I had the same problem. Just replace the battery, fully charge the new battery, set your date n time and you are all good to go.
Add a comment
Add your answer
Alx V will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 31
Past 30 Days: 144
All Time: 15,178
