2.6 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.2 GHz) with 3 MB shared L3 cache. Released February 13, 2013.
120 Questions View all
MacBook not running off battery after replacement
The battery in my MacBook Pro A1425 was draining fast and had to be charged constantly, so I decided to buy a replacement.
I replaced the battery, it’s recognized by macOS, but it won’t run on battery power, and it says it’s not charging. It only runs with the power cord connected.
I tried to put the old battery back, but it now has the same problem, won’t run of the battery.
So now the new battery is back inside.
Tried resetting SMC a couple of times, but no difference.
This is what coconutBattery tells me.
What is there left to try?
Add a comment
It’s possible you got a bad battery, I’d try changing it again. Maybe this time from a different vendor.
Add a comment
Any Luck with this ? My A1425 does not recognize the battery after I changed the trackpad. I am getting ready to change the battery considering that it is about 5 yrs old and probably done with the cycles. But just wondering if I might run into this issue since I had no issues with the battery prior to replacing the trackpad.
1 Comment:
Nope, no change. I have not tried replacing the battery yet again.
I replaced it with another battery before the one that is currently inside, that one did not work either.
So I have tried two replacement batteries, and the original. And neither of them is charging, or can be run on battery alone.
by
Add a comment
Add your answer
Jens will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 137
