The GMT800 Silverado/Sierra 1500 and 2500 (non Heavy Duty) (light pickup trucks) were released in 1998 as 1999 models.
26 Questions View all
What is rear diff oil burning up so fast?
My rear diff oil is black and smells almost immediately after changing it to fresh recommended oil.
The previous owner I believe never changed it but I have had it changed twice in the past two days.
both times it was black with only a 30 minute ride.
Also after driving on a dip the howling sound started and has not stopped even after the diff oil changes and a center barring mount change.
pls help
Add a comment
1 Answer
Unless you clean out all the old oil and the carbon build up off all the parts the oil is going to change rather quickly. If you’ve changed diff parts and are getting a howling sound you might need to change the shims as the backlash may need to be adjusted.
Add a comment
Add your answer
Jack Vampa will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 23
All Time: 273
