Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
2273 Questions View all
I dropped my iPhone 7 and both cameras and flashlight stopped working
I dropped my iPhone and suddenly the both cameras (rear and frontal) and the flashlight stopped working. What it could be? Does it have a fix or its better to replace the phone with a new one?
Add a comment
Chosen Solution
The rear camera is the key here. The front camera and flash will not work if the rear camera is damaged and cannot be enabled. So the simple thing to try is replacing the rear camera with a known-good replacement part (or from a quality vendor) to see if that solves your problem. If it doesn’t, then you may gave a logic board issue. Repairing a camera issue at the board level is relatively straightforward and much less expensive than replacing the device.
Score 3
1 Comment:
Thanks! I'll try this one
by
Add a comment
It’s probably a board level repair. You could try and replace the cameras but it probably won’t do much. You could also try and do a full reset and then it might start working again.
Score 1
2 Comments:
Thank you! I'm doing a full reset right now. If it don't work, do you think i need to replace the entire logic board? Is it worth it?
by
At that rate I would just upgrade to a new phone because the iPhone 7 has so many other problems like the audio ic boot loop problem etc.
by
Add a comment
Add your answer
Eduardo Wichoski will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 857
