Why did my radio stop working?
I have got in my car and my radio hasn’t turned bk on I’m not sure why
Could be various things that cause it to not turn on, but the most likely cause will be a blown fuse. Will have to check for your specific car where the fuse is located for the stereo. There is also a fuse on the rear of the stereo itself on some models so this may be worth a look. Other than that it could simply be a faulty stereo or loose wiring at the back of it.
The easiest way to check a fuse without the proper equipment it to pull it out an visually check if you can see a break in the wire in the plastic part between the 2 metal prongs.
Past 24 Hours: 4
Past 7 Days: 6
Past 30 Days: 20
All Time: 209
