A high-end PC workstation by HP, released in April of 2012.
Fatal memory error 927
Hi,
My HP z820 has this problem: 927 Fatal Memory Error. memory error detected CPU1 DIMM slot 5 or 6. The system required rebooting by press F1 button,
Please can you give me any advice or instructions on how to solve this.
Regards,
1 Comment
Same problem here , did u find any solution ?
by
Add a comment
1 Answer
Chosen Solution
ghazwan_khalaf  here is what HP has to say:
Message:
927—Fatal error on DIMM in slot CPU X DIMM Y
Cause:
Fatal multibit ECC error detected on the DIMM in the slot labeled CPU x DIMM y (where x is 0 or 1 and y is 1 - 6), as labeled on the system board.
SOLUTION:
Replace the DIMM in the identified slot.
Score 5
1 Comment:
my gratitude
by
Add a comment
Add your answer
ghazwan_khalaf will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 28
All Time: 7,055
