Samsung tab pro sm-t525
Hello,
i have a samsung tab pro sm-t525.
device charge bad so i replace 2x the charging port and the batterij but still same problem.
device stops charging after 2-3 min.
Hello,
vdb consulting since you already changed the battery and the USB connector (hopefully it is a good repair and the parts are functioning normally) you want to go ahead and check the charging circuitry according to the schematic
Then it’s probably a battery issue here is the replacement.Samsung Galaxy Tab Pro 10.1 Battery Replacement
No, we change the battery also, no result..
Stops everytime with charging
Did you get them from a good place like ifixit?
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 12
All Time: 271
