Repair guides and troubleshooting for the EasyNote TJ65-CU-030GE, a 15.6" budget laptop by Packard Bell.
17 Questions View all
No powering on, not even a light
EasyNote Te
Have tested the power cable (friends) so not the cable’power.
Have taken the battery out, held switch down for 20 sec’s then plugged in the cable, still no joy, not even a light.
1 Comment:
it may be a software or internal computor issue try go getting it repaired by a person licened to do so to avoid damaging your pc any further
by
Add a comment
This is internal damage, The Display Cable might be loose or damaged, you will probabally need a professional to remove the screen. Its easy to put the cable in but it is also very easy to destroy the cable.
Add a comment
Yes i did so,but still is not powering or showing any light
Add a comment
Add your answer
Alan Barber will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 33
All Time: 2,103
