Samsung's entry level Android tablets. First introduced in 2014.
118 Questions View all
The Difference between a SM-T377P and SM-T377A
So I am trying to order parts for a Samsung Galaxy Tab E SM-T377P (digitizer glass and USB charging port) but can only find the parts for the SM-T377A. I am Fairly sure that the only difference between the two is the Network carrier (SM-T377P=Sprint/SM-T377A=AT&T) but wanted to make sure that there is not a small hardware difference I am overlooking . Thanks for the help Bros / Female Bros
Add a comment
1 Answer
Chosen Solution
Both parts are available on ebay and work on different model numbers of the tab e. The port is probably the same as it's soldered to the
Score 3
3 Comments:
logic board.
by
Yea I wrote motherboard but it takes parts off some of my answers for some reason
by
So just I am understanding correctly, the only difference is the number that indicates what carrier that sells it. but the hardware is the same and are interchangable? Thank you for your help.
by
Add a comment
Add your answer
Zach Miller will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 769
