Overheating and battery drain
Hi there,
After I replaced my broken screen, battery started to drain really quickly, it lasts for no more than 3-4 hours with normal use and the battery area gets hot. When on standby it also drains battery much faster than usual. The device is 3 years old and battery health is 87%.
I first checked if it was software related by doing a fresh install wiping out the previous installation. No luck.
I changed the screen just in case it was faulty but the new screen didn’t change anything.
When it is connected to the charger it doesn’t get hot. So I’m suspicious the issue is with the battery… though it’s weird that the battery has gone bad precisely after the screen replacement.
I’ve connected a power bank, I guessed that if it was the battery it shouldn’t get hot but it does get hot with the power bank connected. Since it is 4400 mAh it should last for a couple of days minimum.
It’s been running for 6 hours now but I have no way to tell if the power bank is depleting faster than usual but wait for a couple of days :-(, it doesn’t look good, the phone gets pretty hot.
I’m not a pro but have opened a repaired lots of iPhones in the last 8 years (kind of a hobby…) and I’m lost here.
Any suggestions before I change the battery? I don’t want to keep opening and closing the phone until I have replaced every single part but the motherboard…
Thank you!
Update (04/06/2019)
Update: the phone has depleted the a 4400mAh power bank in 12 hours so for the time being I’m ruling out the battery, the screen (quality original replacement) and the front camera which is also original and replaced after the problems started (the second screen didn’t carry its own camera).
I´m gonna start disconnecting cables to see if I narrow it down.
