Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
How to disable wifi connection
Hi
My workplace demands my iphone to not have cameras and wifi connection for security reasons.
I took the cameras out easily but when I followed the wifi replacement guide and took off the antenna at the bottom, I had full wifi signal and no cellular network (3g).
I have to disable the wifi so I'll be able to bring my iphone to work.
Please help me locate the right part I have to take off.
Thanks.
Update
I tried to remove the EMI plate (the one that is at the upper part of the iphone above all the connections.
Wifi still works.
Tried to bend the little gold metal tooth that touches the frame at the upper part of the iphone and still there is wifi signal (full strength!)
What can I do?
I found this:
http://pdf.eccn.com/pdfs/Datasheets/Broa...
I can unsolder the 2 top right legs of the chip but I really want to avoid it.
Thanks
Score 1
Add a comment
Chosen Solution
Buy a old phone 4 work that has no cameras and wifi and stop destroying a good iPhone!
Score 1
1 Comment:
I'd agree-you risk permanently damaging a perfectly good phone just so you can have it at work? get an old cheap phone with no wifi so you can be contacted and leave the expensive iPhone alone
by
Add a comment
simple turn on aircraft mode this will permanently disable the wifi on the device
1 Comment:
that's a temporary solution, you can just still just switch the wifi back on whenever you like.
by
Add a comment
Add your answer
Oudy Even Haim will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 692
