The Durango was marketed as a sturdy truck-based SUV designed to hold up to seven passengers and tow up to 7,500 lb (3,400 kg) when properly equipped.
19 Questions View all
How do I go about r and r ing a bad freeze plug?
My sons 1998 Dodge Durango had a cracked radiator. We have replaced the radiator and started refilling the system and there she blows, a steady stream of fluid coming from the front most freeze plug on the passenger side of the block. Is there an easy way to remove one of these? I remember wrestling with one years ago and I seem to remember it being a pain in the a__!
Add a comment
Drill a pilot hold get a slide hammer thread in a course stud grab it with the sh chuck and give it a few wacks if that doesn't do it hit it on the lip and wack it in turning the plug sideways in the hole yank with vise
Add a comment
I use a screwdriver that I can hit with a hammer, and drive a hole in the middle, they pry it out.
https://www.youtube.com/watch?v=lqHVNqwK...
Make sure you use a little RTV when you re-install it.
Add a comment
Add your answer
alan.thomas65 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 26
All Time: 84
