2.6 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.2 GHz) with 3 MB shared L3 cache. Released February 13, 2013.
120 Questions View all
Battery capacity decreasing after swap
Hi, everyone,
so I bought a replacement battery here and i switched and everything was ok for a few hours, then, after calibrating, reseting nvram and the smc, coconut battery is giving me weird reading.
Just when I installed the battery, the design capacity was at 100% as it should be, but after only 2 cycles in, and all the calibration and reseting, coconut battery is telling me the battery’s design capacity is at 89%.
Am I doing something wrong? Am I missing something? what’s going on? again this is a fresh batty from fixit and I did calibrate it twice, that’s the 2 charge cycles the battery has right now. I can always try again but this seems weird and I don’t know if its normal and it’ll stabilize later or if this battery is defective. Ill attach some screenshots from coconut battery.
Thanks!
Score 1
1 Comment
Yep! You have a bad battery, contact the seller for a replacement.
by
Add a comment
1 Answer
Chosen Solution
I’d give it a chance and calibrate it again before going though all the work of replacing it again. Let it drain down to 10% then fully charge it again and see what reading you get.
Score 4
1 Comment:
Thanks! ill probably calibrate it again tonight and see what happens
by
Add a comment
Add your answer
Jorge will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 17
All Time: 224
