Time /Date are incorrect
The time and date are not correct and when I change them to correct ,the next time I turn it on it’s back to the wrong date..
Couple things to check. Out of misguided paranoia, is your Location turned off in the Action Center/All Settings/ Privacy/Location ? Should look like this:
Also, check this - Win + R/ services.msc Scroll down to Windows Time Check if it's running and on Auto trigger.
If not, r-click/select Properties/ set Startup to Automatic/ OK.
If these both check out and you try to turn off auto sync and manually set time.
And let me know how’s everything going after that, thanks!
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 177
