Repair information and guides for the iPhone 8 that was released on September 22, 2017. Model: A1863, A1905
iPhone 8 only wireless charging
Hello I have a iPhone 8 that is not water damaged nor has it had any kind of severe drops. The charger port doesn’t work but only wireless charging works. When put on the wireless charger it’s stuck in a boot loop. Does this mean the battery is bad or does it mean the charging port is bad? If I replace them will it work again? Thanks!
Add a comment
Chosen Solution
Charging port probably - it would be my first guess.
The second will be cable damage.
Third - soft/hard issue.
You check if it has not go any dirt inside lightning port. Then begin the repirs:
At first try to connect your phone with iTunes - if your PC detects your phone then you should hard reset it (put it into recovery mode and go for it). If your PC doesn’t recognize your phone then I’m sorry - daughter board replacemen required.
Score 1
1 Comment:
Thanks, I will try
by
Add a comment
i have a problem what happens if it only works with wireless charger but the wire chargers don't work at all with the iphone
1 Comment:
It needs a new charge port assembly fitted.
by
Add a comment
Add your answer
Hunter Wilcox will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 8
All Time: 4,085
