2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
781 Questions View all
What are common (idle) temperatures for this machine? (2015, 2,8 Ghz)
Hi,
I bought a used 15” mid 2015 2,8 Ghz Model and have never owned a “high end specs” MacBook Pro Model before (only the lower tier versions of 15” MBP 2012 and 13” Models but those without dGPUs of course).
I have some interesting observations regarding the machines temperatures and fan speed.
I hope you guys can help me and report your common temperatures you have while running this machine.
Now my problem with this “new” 2015 machine is that the fans run constantly rather high than low and whenever I use the machine ever so slightly, creating a spike in CPU usage over a short time, the fans immediately run high and the macbook gets close to annoyingly noisy. A CPU Usage of only 14% results in fans spinning at 3500 rpm and the machine going up to even 70-80°C really quickly. Merely browsing a website like this makes my machine also run at 2800-3300rpm and 65-70°C.
My concerns are rather for the idle temperatures because I figure, running the CPU at 100% during my work with After Effects/Premiere/etc makes the fans spin at 6000rpm max naturally. With “yes” CPU Tests in Terminal and other Benchmarks/Tests the machine reaches 90-98°C easily and comes very close or even reaches its tJunction Max at 100°C. Luckily, there are no signs of excessive thermal throttling though and the machine will run at its 2,8 or more Ghz using Turbo Boost without dipping lower, even for longer periods of time .
Now, of course I understand, simply put: more Ghz = higher temperatures, dGPU = higher temperatures as well. But this somehow still feels strange to me.
As I have never experienced such behavior from a Mac since the Core Duo Models before (it’s quick changing high fan noise is amusingly the thing I have always hated most about most Windows Laptops), I wonder if anything is wrong my machine (hidden water damage or another hidden hardware defect?) or if this in fact is totally normal behavior for this machine, having both the most powerful Intel i7 2,8ghz of that years MacBook models and the AMD Radeon R9 M370X 2 GB.
I use Activity Monitor, SMC Fancontrol, TG Pro and Intel Power Gadget to monitor the machine.
I have so far done:
— NVRAM/SMC Reset/reinstalled MacOS/etc./etc.
— disassembled, cleaned and checked the machine for signs of water damage (no obvious marks found)
— Reapplied heat paste (two times with different methods and amounts) (MX-4 and Cooler Master MasterGel)
Of course I know of methods like using fan controlling tools to reduce the temperature but in my case it’s the combination of the already high temperature with the already fast spinning fans creating a lot of noise. So “adding more noise” by turning up the fan speed would not really be an option or actual solution to my problem.
Any other sources on the internet say their “2015 MacBook Pros” run at ~41-50°C during idle, some mention 50-60° but there is no way to know if their way of measurement is either the same (CPU Core? CPU Peci? Running SMC Fancontrol at 6000rpm constantly?) or if they actually have the very same 2,8ghz Model and not “(some kind of 2014) MacBook Pro (13” with an Intel i5) 2,8ghz” when they say "Go to the Apple Service, you might have a Virus! My 2015 MacBook Pro runs really cool! ” ;-) I hope you get the picture.
I hope some other users of the 2,2ghz, 2,5ghz and 2,8ghz 2015 Models can chime in to find some reliable answers and thoughts through the board. Maybe even for other users, who hopped on the apparent recent trend of “getting the good old 2015 MacBook Pros in 2018/2019” instead of the newer 2016/2017/2018 Models with Touch Bar and the keyboard, which still seems prone to failure.
Thanks!
Score 7
8 Comments
First I would advise you to remove SMC FanControl and just stick with TG Pro.
Can you post a snapshot of TG Pro main app window so we can see the temps. I want to see the high water marks besides what you are running now. Do make sure you've taken out SMC FanControl as it will bias what the system is telling us Adding images to an existing question
What is the size of your drive and how full is it?
Did you run the built-in diagnostics? Restart your system and press the D Key. Did you get an error?
Reference: Mac startup key combinations
Which version of MacBook Pro did you get?
15" MacBook Pro 2.8 MHz i7 Mid-2015 (IG)
15" MacBook Pro 2.8 MHz i7 Mid-2015 (DG)
Given what you are trying to do you really need the dedicated GPU model (DG) over the Intergraded model (IG)
by
Thanks for your input Dan,
Like I mentioned I have the discrete GPU (DG) Model.
Yes I already sticked to TG Pro only, but just for measure used SMC Fancontrol to get the °C number to compare with other users.
I ran "D-Diagnostics" a couple of times, always giving No Errors.
Regarding the SSD/hard drive:
I have upgraded my machine with a 2TB Samsung 970 Evo+Adapter but can rule out that as a source of error as well as I have the very same result with the stock 512GB SSD from Apple.
With the Samsung SSD I even tried two different NVME adapters with no difference.
Space left is literally "as much as possible" (1.9TB or ~480GB respectively after a new installation of MacOS, and yes, measurement took place after indexing and any background activity).
Temperature readings on both SSDs are a moderate 31–40°C on both, only after using Blackmagic Disk Speed Test it slowly crawls up to 50°C, if at all.
Interestingly this barely affects the CPU temperature.
by
Please post a snapshot of TG Pro so we can see what it is showing.
by
For me Apple is so bad with this machine. I own a MBP 2015 2.8 GHZ, DG. I just to launch face time, or some stupid bad quality you tube videos and I have to tight my MBP to my desk or its fans make quite vertical force that my MBP will fly.. Just start safari an this piece of aluminum get really hot.. I hope apple improve its performancel with its new m1... I have another Intel Windows Laptop and almost never I heard its fans and temp is warm. I dont understand what apple is proud of what. Sadly Steve pass away and tim just to know sell expensive things. Its a shame how are destroying the core values of steve(rip) efforts
by
Exactly the same. I don't know how to manage it.
Maybe is there a way to "tune" it to make it think it's lower-end model so it will tame it's noisines and lower the speeds? I would be OK with that
by
Show 3 more comments
Add a comment
Most Helpful Answer
I’’m not sure if you have a true hardware issue or expecting more than what this given system can offer you.
A laptop is not a desktop! It just doesn’t have deep cooling options.
Often I find people over stressing their system either because its RAM and/or storage is limited given what they are trying to do. Or, are running Apps the system is just not able to support given its age and/or the shear size of the given project.
Both Adobe After Effects & Premiere are great apps but they are both CPU/GPU as well as RAM/Storage hungry depending on how big or complex the project you are working on. You likely need to monitor your processing and RAM usage using Activity Monitor.
Given you have a SSD drive you likely need to reconfigure how you are using it, and you maybe undersized as well. I strongly recommend you remove as much as you can from your boot drive as the system leverages it for Virtual RAM (VRAM). You may need to review your SSD’s health unlike HDD’s SSD wear every time the given block is reused. When you have a very full drive the system needs to work harder to move less used blocks for more heavily used blocks (wear leveling). To reduce this you need to leave more of the drive unused. As a rule of thumb I recommend a 256 GB or smaller have 1/3 of the drive left unused. larger drives 1/4. If you are working on large projects you might need more!
Score 1
7 Comments:
Thanks for your second reply.
I answered some questions about the SSD and Model in your comment above.
Bear in mind that, like I said, I'm not talking about using After Effects/Premiere and wonder why my machine is running hot. That's perfectly normal and to be expected.
It's rather other way round: I put close to zero stress on the machine, merely browsing a website like iFixit.com or playing music from itunes and that makes my CPU reach temps of around 60-70°C and fans running at +3500rpm at 11-17% cpu usage and still having 10gb RAM of my 16GB installed left.
Getting back to your answer, "A laptop is not a desktop! It just doesn’t have deep cooling options." might be the case. Like I said, all these temperature readings also might be perfectly normal for this specific 2,8ghz+dGPU machine but I simply don't know as I have no other sources or comparisons for this kind of machine. Hence my questions/search for other peoples experiences.
It's a pity ASD isn't available for the 2015 Machines anymore.
by
Apologies for digging up an old thread, but I recently repasted and cleaned my 2015 15" rMBP w M370X and found that the temps spike in particular if I've got an external monitor connected as it invokes the GPU for that and conceivably additional tasks too. Doing mundane stuff, including Safari and Chrome with an unhealthy amount of tabs between the two (12 in Safari, 14 in Chrome .. some using live chat connectors), outlook, office apps, iMessage, WhatsApp, Teams and MS Remote Desktop.. with two external TB2 monitors connected she's sitting in the low to mid 60°C for CPU and 61°C for my GPU.
If I unplug the monitors and run the exact same apps using just my built in display, after about 2 minutes it goes down to 54°C for the CPU and 35°C for the GPU.
I used thermal grizzly Kryonaut paste.
by
@kotskat - Yes that makes sense! The dedicated GPU needs to work harder to process the image page to be spread across the displays (both internal and external/s) Laptops just don't have the deeper cooling than a desktop. I have a 2013 MacPro which ramps up its temp when I enable two displays as well.
by
When you said that the system uses the boot drive for VRAM, I think you meant that it uses the boot drive for swap space. In systems without dedicated VRAM, Shared RAM (SRAM) uses your system's memory (RAM). For example, 256 MB of SRAM means that the system can use up to 256 MB of your RAM for the graphics card. Using SRAM is slower than using VRAM, and using swap is slower than using RAM. Using your drive for VRAM would simply be too slow. You are right that using swap burns up your drive health, but it would be a thousand times worse if it was your graphics card instead of your CPU, as a graphics card without dedicated VRAM would need to constantly be using your storage.
by
@ethang17001 - VRAM in this context is Virtual RAM not video RAM.
Depending if you have an IG system which only has the Intel graphics engine within the CPU, or if you have the DG system which offers the discrete AMD GPU the video RAM will be either a reserved area of main RAM memory or the AMD has its own dedicated video RAM.
by
Show 2 more comments
Add a comment
You know, I wonder but I experience exactly the same behaviour from exactly the same machine. I’m very sad, as this is a totally opposite to what I expected from Mac (and I had reasons to).
It whines sometimes even while easy web browsing. It does it stupidly, temps might rise to ~65 only, but it ramps up and to 50+% and doesn’t stop till it’s ~50. When discrete GPU invokes, even the slightest load in C4D viewport with the lightest model imaginable may crank the fans up to 6000 rpm! INSANE!
I cleaned and repasted it, undervolted, I did everything I could but as soon as I launch C4D and start working it kills me with noise. I’m toasted, it’s unbearable.
Why does it happens? Is this an issue or a fault of the model? Did previous generation with GT 750m behave the same? How da **** to solve this? I’m about to sell it asap, can’t bare it.
Help us please ;(
1 Comment:
I deal with a fair amount of students in the arts. C4D is very process intensive application! Depending on your project size and run time you can run hot.
RAM and storage is very important here! You really need 16 GB of RAM (the limit within this series) Getting a newer model with 32 GB would be ideal.
Storage can get tricky! You want as much free space as you can within your internal drive. My rule of thumb is to have at least 1/4 of the drive empty. With large image/video work this is way to little!
I have 2015 15" MacBook Pro's which I use when I'm on the road with my photography. It has 16 GB or RAM and a 2 TB SSD. It only has what I need for image processing and presentation. I leave half of the drive empty for virtual RAM, caching and scratch space fo my apps. I also use external TB SSD drives to hold my work.
Depending on your App you may find it uses more GPU than CPU processing. You may find using an external GPU system might be useful for you. I have a desktop system which I use for the heavy lifting.
by
Add a comment
Add your answer
Markbook will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 110
All Time: 15,127
