The 2018 version of the Samsung Galaxy A7 smartphone released in October 2018.
Power reset or unknown upload mode
Hi, i have a problem with A750SN got stuck in bootloop. After i tried to enter download mode it shows me only “Power Reset or Unknown Upload Mode”, i have tried to connect it to Z3X and click on the “Reboot to Flash” the screen says OK but in the phone screen nothing is happening.
I will write the whole text that apears in the screen of device.
[RST_START = 0x1000000 ]
ECT : PARA002n
LPDDR4 manufacturer = Samsung
LPDDR4 Process ver = D18_B
LPDDR4 Size = 4G
LOT_ID = N0000
CHIP_ID = 0753b6b4924c
[TMU] 33, 29
asv_table_version : 2
big grp : 7
little grp : 7
g3d grp : 7
mif grp : 7
int grp : 7
fsys grp : 7
cp grp : 7
Please uncheck Auto Reset option of RDX!!
And do HARDRESET by using volume down + power key 7 secounds!!
CODE MATCHED (0)
Fatal exception in interrupt
PC is at hard_reset_hook_callback+0xdc/0x120
LR is at hard_reset_hook_callback+0xdc/0x120
I have tried the “ hardreset by using volume down + power key” but it still stuck in samsung logo.
If someone has any idea how to exit this and enter the download mode i would be very thenkfull.
1 Comment
Upload mode Forced upload mode with key A10
by
Add a comment
Chosen Solution
The phone was water damaged and wouldn't recognize the USB cable.
Score 1
1 Comment:
press power button + volum up and home button then yoU need to do factory reset data and go restart your phone and go to factory setting
and reset ur phone
by
Add a comment
Most Helpful Answer
after I use Z3X and click on the “Reboot to Flash” , phone will get in download mode. Then i just put the file and click on flash
Score 2
Add a comment
My phone have problem video player out repair my phone
Add a comment
Ok thats stupid ur phone has water damage mine has no water damage and says the same thing i just used odin on it so thats aload dog duddy im having the same problem if someone told me what the rdx was i could do it if u google rdx and android tells about cars with android fearures
2 Comments:
U must press power button with volum up and home button to get in android mode and do a hardware reset and clean all ur datas then go into ur settings of phone and do factory setting and reset your phone another time then it wouldn't come
by
@Buisan Kahbo I've try to press power button and volum up button only cause my phone doesn't have home button, but it's still doesn't work. What should I do?
by
Add a comment
حالت آپلود اجباری حالت آپلود با کلید A10 The second SIM card does not work either
Add a comment
Add your answer
Adrian Zymeri will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 67
All Time: 15,565
