Introduced in 2016, the Brother MFC-L6700DW monochrome laser All-in-One addresses the business needs of workgroups with higher print volumes. It boosts printing and copying at up to 48ppm. The large 520-sheet capacity paper tray holds more than a ream a paper for fewer refills, and for additional capacity add-on trays boost total capacity to 1,610 sheets.
8 Questions View all
no power up when turn on
Not operational when turned on. Completely off
Score 2
Add a comment
1 Answer
  1. Trace the power from source.
  2. Check the operation of the power switch (once in our office a printer’s power switch was found to be infested with ants).
  3. After that check the low voltage power supply board, if you can work out how to remove the covers.
Add a comment
Add your answer
Roman Misandzhi will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 7
All Time: 372
