Released in 2013, the IdeaPad U430 Touch, Model #20270, is a streamlined 14" Touchscreen Ultrabook by Lenovo. You can find the Device information and Model number on the bottom of the case.
6 Questions View all
Laptop will not power on
When I press the power button, the keyboard backlight flashes briefly, then nothing. Same with power supply attached / battery only.
I’ve tried the “disconnect battery, press power button 10 times at 1 second intervals, then hold 30 seconds, reconnect battery, attach to AC power, power on” sequence, and that doesn’t work either.
There was no precipitating event. I didn’t drop it, or spill something on it. It just stopped powering on one day.
Does anyone have another repair pathway? If you’ve fixed this problem, please let me know how!
Add a comment
1 Answer
It might be the display cable where the backlight isn’t fully functioning. Are there any light indicators? If they are on, it might be your display. If not you might need to get a battery replacement
1 Comment:
There are no light indicators. The laptop doesn't power on when AC power is supplied, so the battery isn't the problem.
by
Add a comment
Add your answer
Jonathan Mandel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 314
