Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
Totally Stuck Pentalobe screw
Hi, I have a iPhone 7 and I’m trying to replace the battery. Unfortunately, one of the screws are stripped and s tuck in the phone. Is there any way of getting in?
Thank you,
Filip.
Score 1
Add a comment
Chosen Solution
Well, I solved it! Unfortunately, I had to sacrifice my housing. I used metal grinder to get the screw out. Thankfully, nothing in the phone was damaged, but i didn’t care about that because I swapped my motherboard into my parts iPhone.
Add a comment
Most Helpful Answer
https://www.youtube.com/watch?v=TEYgVsPc...
this might help you out :)
Score 1
3 Comments:
Thajek you, but I already saw this video and tried all thing
by
i guess now you have to drill and remove the screw and get a pair of new screws
by
What size the drill bit should be?
by
Add a comment
Use a scalpel or a sharpish knife obviously with great care try to find a sweet spot on the screw that the knife will go into and gently try turning it that way, once u have a bit out try using pliers to turn it out…
U could also try pressing the screwdriver really hard/firmly and turning as u push…
Never needed to drill a screw out before
Score 1
1 Comment:
This seems to be a good idea! I’ll try!
by
Add a comment
Stick the phone in the freezer for some time it should contract the metal and make it easier to remove.
Add a comment
after trying everything suggested by the youtube video in @soumya's comment to no avail, i drilled out the pentalobe screw very carefully with the smallest bit i had on hand (0.04"). slow and steady did the trick- there's nothing too fragile right behind the screw so it is possible to drill it out without damaging anything else.
Add a comment
Add your answer
[deleted] will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 47
All Time: 2,055
