Model A1288 / 8, 16, or 32 GB capacity
451 Questions View all
screen not responding when I touch it
I just replace my Itouch 2nd gen screen with a new glass and bezel. i put it all back together and the button works but it won't respond to my fingers on the screen. Could the ribbon cable have moved and it's not making a good connection?
Score 4
Add a comment
Most Helpful Answer
Either it isn't connected correctly or the ribbon cable may have been damaged when you put it back together, it can tear VERY easily. This would cause the touch to stop working.
Score 2
Add a comment
Open it back up and make sure all the cables are connected.
Score 1
Add a comment
It's also possible the logic board itself has a damaged port, but confirm that it's not the digitizer screen itself.
Score 1
Add a comment
Make sure that the Digitizer ribbon is clicked in all the way, that was the problem for me.
Add a comment
If the ribbon cable is plugged in good, make sure you reboot. It is about like the screens, the ipod has to reboot to see that it is connected.
1 Comment:
Just thought of something else, the thick ribbon cable that runs up to the wifi/touch connection board could be damaged also. Changing it is very hard and this is just to reference another place to look.
by
Add a comment
try restoring the iPod touch.
Add a comment
maybe the touch screen has been damaged during yout operation or there is a loose connection
Add a comment
how did you know that this was the problem with the touch screen? the "black resistor" I am having the same trouble with my touch screen. I have restored, rebooted, bought 3 different model screens, tried gorilla tape to hold down a tight connection, used 90% alcohol to clean the insides everything. Everything is working find on the ipod except I can't get the touch screen to work and it's driving me nuts!
Add a comment
i figured out why the touch screen isn't working or responding, this is cause by static tiny rectangle black resistor is blown out, located on the upper pcb right between the square metal and
square plastic(like diamond)
and it is impossible to fix it ,
Score -2
Add a comment
Add your answer
Al Urban will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 43,057
