GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
152 Questions View all
should I replace the LCD or the digitizer alone?
the case is that , the imaging of the iPad is perfectly fine, but I have this difficulty in touching when touching certain parts of the screen (ex. when I am typing a message, at some point, the point where letter A, and N located isn’t functioning at all.. i need to rotate the screen for me to type the letter A and N..) should I replace the LCD ? OR IS it ok if I only replace touch pad or digitizer? pls do give me some advice
Add a comment
1 Answer
Most Helpful Answer
The digitizer has two layers which is touch screen and glass. Replacing that part will fix the touch problem.
Score 1
Add a comment
Add your answer
French Marie Escabarte will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 66
