The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
617 Questions View all
Pulled lcd connector pad
Hey,
i had had a water damage Macbook come in for repair. I took the LCD Connector off because I noticed it was burnt on the right side of the logic board.
anyways, I pulled the connector off and noticed a pad was gone. I looked at the trace for it and it looks like the last pin is on the same circuit. Can some chime in to tell me if I could solder the pin over to that one? And possibly provide a schematic of this connector so I know what it does
Add a comment
1 Answer
Chosen Solution
Actually, it looks like the pad is not connected to anything, at least not on the surface. Perhaps that’s just because the picture isn’t zoomed in enough.
As for the schematic, you have to provide the logic board model number otherwise we’re just guessing.
EDIT
Score 2
5 Comments:
Sorry I desoldered the connector and seen the pad was pulled. I’m curious to know if that pad is ground or not needed for anything
by
This logic board is for MacBook Air 13” early 2015
by
I meant to say "pad" and not "connector" (see edit above).
What is the logic board model number (820-XXXX-X), you will see it silk screened on the pcb.
by
I updated my question with the board pictures . I couldn’t see 820 anywhere on the board
by
It's pin 2, NC as I suspected.
by
Add a comment
Add your answer
Daniel Ringuette will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 101
