A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
Change the HDMI Port
Is it possible to change the port without a heat gun. I have the new port ready along with solder and desoldering wick and of course the soldering iron. I also have flux but not really anything else that would be useful apart from tweezers. I've noticed everyone using heat guns and was wondering how I could just melt the solder with just the soldering iron.
Add a comment
1 Answer
Chosen Solution
It would be very difficult without prior experience or just using the heat gun. You run the risk of pulling pads off the board if you don’t use heat. I would recommend using a heat gun Lowes, Home Depot, or even Harbor Freight. They should be around $30-40 dollars. If that isn’t possible, you would want to remove the solder from the anchor points, which are the four points on the sides of the port that connect to the board. After that you’d want to remove solder from the pads. Even then you still may not be able to get all of the solder off, which would mean when you try to pull off the piece it might still rip off some of the pads. It’s generally a low success rate without a heat gun.
2 Comments:
Would this be okay?
VonHaus 2000W Heat Gun - Remove Paint, Varnish, Dissolve Adhesives, Shape Plastic Tubing & More - 2 Heat Settings: 350°C & 550°C - for DIY, Home Improvement & Restoration https://www.amazon.co.uk/dp/B076X3HLM1/r...
by
That one could work, but the temperature can't be controlled and the nozzle is bigger. This is the one like we use, and it's not too much more expensive. https://www.amazon.co.uk/858D-Rework-Sol...
by
Add a comment
Add your answer
R Hussain will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 30
All Time: 3,777
