What screwdriver do I need
Can someone link me a screwdriver from the ifixit store that can be used to open up a joycon
@andrewifix you need a Y00 bit for the backplate iFixit Precision 4 mm Screwdriver Bit Even better if you get the kit so you have all drivers for most common repairs Mako Driver Kit - 64 Precision Bits
Product
$39.95
Product
$2.99
For the inside of the Joy-Con, you will also need a Phillips #00: Phillips #00 Screwdriver
@oldturkey03 gave you some good options, and you hopefully fixed your controller by now, but if you only need a fixed blade screwdriver to open your Joy-Con or Switch, iFixit sells a Tri-point* Y00 Precision Screwdriver
*AKA a Tri-wing screwdriver. It is different from an actual "Tri-wing" Screwdriver. If you are opening a Switch Joy-Con, the screwdriver tip should resemble a Mercedes logo and not a shuriken. These nuances between screw types and more are in this Nintendo Switch screwdriver wiki resource.
Past 24 Hours: 29
Past 7 Days: 190
Past 30 Days: 677
All Time: 40,794
