Device and repair information for the 60" LED HD TV by Samsung released in 2013, model number UN60FH6003FXZA.
205 Questions View all
What should I do when I cannot turn my TV on after plugging in a USB?
Hi there. So, a while ago, we watch a movie on the TV. We plugged in a Flash drive and it turned out normally. There was no problem with the TV recognizing the Flash Drive as well as the Folders in it. But now the TV won’t turn on.
Score 2
4 Comments
I connect my tv to a device and then the screen black out
by
I accidentally plug in a cheap portable fan with the a micro usb, and the tv turn off itselft and cant turn back on
by
@Raiyan Farhan you probably fried either the power supply or the whole main board itself. How do you accidentally plug a fan in to a tv?
by
@Dylan Devries im about to connect it to my phone, but i plugged the wrong cable . Thanks for your reply btw
by
Add a comment
Most Helpful Answer
hannahjazziesantiago  make sure you have power on the outlet. Remove any input source from your TV. Unplug your TV and hold the power button down for 30-60 sec. Then reconnect the power cord and see if it starts up. Reconnect one input source at a time. If that does not work you want to check the power board to see if you get power to the set. Of course you will have to remove the back from it. Post some good images of the boards etc. with your question so we can see what you see. Get a multimeter and check for power on the main fuse. Adding images to an existing question
Score 2
Add a comment
You may have infected your TV with a Virus! Samsung asks users to please virus-scan their TVs
You should also check your PC’s and the storage devices you have used (i.e. USB thumb drives)
Add a comment
Add your answer
hannahjazziesantiago will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 33
All Time: 3,412
