Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
466 Questions View all
3DS Charging only for a few seconds before promptly stopping.
For details I haven’t use my 3DS for about week or 2 before deciding to play it,
3DS is working fine until I charge it, would only charge for a few seconds and its not even fully charges.
Decided to buy a new charger, same results, change the battery, same results.
Although if I leave the 3DS for a long duration of time take for example 4 hours and proceeds to charge it again, the charging would last more by a minute or more until it stops.
The 3DS recognise that a charger is on it with the battery charging symbol on the top right of the screen but instead of a orange indicator. a blue one appears.
Any idea what’s the problem?
Add a comment
Most Helpful Answer
Your chargers are fine. This is a battery problem.
You can read this guide for replacing your 3DS Battery: Nintendo 3DS Battery Replacement
Here is a replacement battery: Nintendo 3DS Replacement Battery
If you need any help please reply to this answer.
Thanks,
John
Score 1
5 Comments:
I haven't actually brought a new battery, although I have two 3DS batteries (one from the console itself and another from a broken one), decided to swap the batteries same result. I can always try to buy a new battery but that will take time on my part.
by
Are you sure both batteries actually work? Is there an swelling on the batteries?
by
I actually tried using the my old broken 3DS to charge, its working on both batteries. The problem probably lies on the charging port of my current 3DS or Power receivers... I could always perhaps use my old 3DS as a source of spare parts but I'm not confident with my soldering skills.
by
Anyway thank you for taking your time on my problem, sir John.
by
I found an article on someone who has had this issue before, which you can find here: My 3ds won't charge anymore
Credit to @lpfaff1 for that answer. Feel free to mark this as answer if this solves your problem.
by
Add a comment
If the battery is fine, check the F2 fuse
Add a comment
Hello, I was having the same issue. I removed the back panel and simply removed the battery, blew off the battery slot, and put it back in. And now it’s working fine. I went for about 2 years without powering it on.
1 Comment:
Maybe, but it was working like a week before it just wouldn't turn on. I can't try it cause I already sent it to get repaired. Thank you though. I also had gotten a battery and the charge light stayed on but it still wouldn't turn on.
by
Add a comment
remove sd card and game card and retry. same problem for me and the sd card was at fault.
Add a comment
Add your answer
Robin Oliva will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 17
Past 30 Days: 114
All Time: 10,057
